073 cold weather package n/a could somebody give information about this? Engine preheater standard?
096 first-aid kit n/a standard in some countries. Located underneath passenger seat
199 no catalytic convertors 708 only first production year(s), later this option was discontinued
209 limited slip differential (final drive) 763 25% limited/lock, 3.15 ratio
214 asc+t automatic stability control with traction control n/a became standard on 90-> models
219 leather sport steering wheel 73 diameter 385mm instead of the 380mm for the 3,5 and 6 series. Those extra 5 mm will do the job.
220 LAD self levelling rear suspension 1281 only for the rearaxle/ standard on 750i(L) models and all L models / not available for US short wheel based models
222 EDC electronic damper control II 1896 rarely seen option/ also available on the 730i/735i models but strangely almost as twice as expensive/ no OEM-aftermarket replacements available
223 EDC electronic damper control III n/a see above
235 tow bar n/a
240 leather airbag steering wheel 2168 steering wheel adjustment isn"t possible with this option in first production year(s)/ not possible in combination with sports steering wheel / always leather
245 electric adjustable steering column n/a radial, not sure about axial
288 wheel cross spoke 225/60R15 n/a
291 wheel cross spoke 240/45 17 inch TRX 1246 expensive TRX wheels, therefore not very desirable/ also 235-45 was available
293 TD alloy wheels & tires n/a
302 anti-theft alarm with remote control n/a remote sensor is located near sunroof switch and interior lights
303 additional anti-theft n/a what does this mean? Handcuffs?
314 heated outside mirrors n/a virtually standard on every 750i(L)
320 no 750 badge on the trunk --- the only option without extra cost
339 shadow-line n/a black trim strips on all window frames (both interior & exterior)
black side-protection mouldings
body-coloured bumper-top trims
body-coloured headlight washer jet nozzle (if applicable)
354 anti-glare windshield strip 72 virtually every E32 has this option
365 laminated safety glass rear window with invisible heating wires 226 *extremely* rare!
401 electrical sliding and lifting sunroof 1567
415 electrical rear sunshade/rear screen blind 192 in some countries standard on 750iL models
416 electrical rear sunshade/rear screen blind and rear door manual blinds in the main and quarter window n/a those rear door manual blinds are very sought after, kinda holy grail
428 triangle + first aid kit n/a in some countries standard equipment
430 automatic dimming interior rearview mirror n/a most wanted sought after item, can be retro fitted
458 electrical seat adjustment for driver and passenger 1705
459 electrical seat adjustment for driver and passenger with memory (also mirrors), dipping right mirror and comfort seats 2393 standard on 750iL models
460/461 electrical rear seat adjustment n/a standard on 750iL models (and all iL models?) / in combination with 499
464 ski sack 176 a truly must_to_have....
469 standard front seats n/a probably sort of downgrading the seats, never seen this
481 sport seats 2275 included with option 458
sport seats 2963 included with option 459
488 electric lumbar support driver seat 285
489 electric lumbar support passenger seat 285
494 electrical heated seats driver/passenger 446 in some countries only in combination with 459/ in some countries standard on iL models
496 seat heating for rear seat n/a in some countries standard on iL models
499 electrical adjustable rear headrests 280 in some countries standard on iL models
500 headlight washing system 475 standard on iL models
522 Xenon headlights n/a only from "93->. There are 2 types: Bosch and Hella
528 auto air re-circulation n/a
536 park heating (preheating interior) with timer (from webasto) 1408 included with option 537
537 park ventilation with timer 113 standard on iL models (preheating system is separate!)
560 2 reading lights rear compartment 127 standard on iL models
564 interior light package n/a
571 larger alternator n/a 140 amps version
634 Telephone installation for BMW C net n/a most likely you can"t use this anymore, it"s obsolete. Some reported converting this kind of installation.
676 premium audio hi-fi system & speakers n/a amplifier located at the left side in trunk
685 radio aerial for above n/a for telephone? Only in combination with 634? Anyone a clue?
687 radio pre wiring n/a standard, but not sure about this
778 marking BMW Individual n/a not sure about this one, can somebody confirm this?
801 build for German market n/a equipped with rare double piston front brake calipers after "92
812 build for England/GB/UK market n/a driver and wheel at the wrong side (no debate here ;-)
820 build for Brasil market n/a what are the differences? anyone?
850 larger gasoline/fuel tank n/a standard on iL models
860 side turn signals (front) 41 standard on US models and some other countries
847/575 extra battery in trunk for cellular telephone n/a only in combination with a onboard telephone
857 preparation for supplemental automatic climate control installation n/a highline version only (?)
899 export vehicle n/a not really an option but more identification
923 narrow kidney grill n/a upon special request, the 750 could be delivered with a small kidney grill and hood/bonnet...now where are talking about a rare option...
925 shipping protection package n/a covered in waxoil, probably only for overseas countries
- standard leather interior (seats only) 2301 initially in 6 colors, standard on iL models
- full leather interior (incl. console, doorpanels, dash) 6772 in some countries standard on iL models instead of above option
- buffalo leather interior (seats only) 3593 this isn"t the shiny, smooth leather but has bit "rougher" surface and it is softer, more flexible. Nice!
- full buffalo leather interior (incl. console, doorpanels, dash) 8257 most expensive option, very desirable/ included with option 415/ if the full leather interior is standard (iL models) this option costed appr. 1355,- extra
ещё немножко кодов было найдена в Архиве конфы. только на е39
хотя некоторые совпадают с номерами опций е34/е32
вот они:
302=охранная сигнализация с ДУ
320=отсутствие обозначения модели на крышке багажника
352=двойние боковые стекла
401=металлический люк в крыше
411=электростеклоподъемники задних дверей
415=электрошторка заднего ветрового стекла
416=шторки задних дверей
423=велюровые коврики
428=знак аварийной остановки
430=зеркала с автоматическим затемнением "электрохром-технология", обогревом и функций автоматического складывания зеркал
431=внутрисалонное зеркало заднего вида с авт. затемнением
438=деревянный декор
441="пакет курильщика"
456=комфортные сидения с памятью (верхняя часть спинки регулируемая) 16 степеней регулировки
459=память положения передних сидений
469=интегрированное в задние сидения детские кресла (2 шт)
473=подлокотник заднего сидения
488=регулируемая поясничная поддержка передних сидений
494=подогрев передних сидений
500=омыватель передних фар
508=парктроник
520=противотуманные фары
522=ксенон
534=климат-контроль
536=автономный подогрев двигателя и салона с ДУ (Webasto оргинальная БМВ) + накопитель тепла
540=кожаный руль с кнопочным управлением, включая круиз-контроль
548=спидометр в Км/ч
555=полный бортовой компьютер
602=бортовой монитор с функцией телевизора
609=навигация
629=стационарный телефон в подлокотнике
672=чейнджер на 6 дисков
676=громкоговорители Hi-Fi:
и
205А AKПП-5 Steptronik.
210А Система стабилизации кузова DSC III.
226А Спортивное шасси.
249А Мултифункциональный руль.
255А Рулевое колесо спортивного типа.
251А Передние и задние боковые подушки безопасности.
347А Титановые вставки в салоне.
403А Стеклянный электрический люк.
423А Велюровые коврики.
431А Система затемнения зеркал.
347A Отделка, алюминий.
473А Центральный подлокотник.
481А Сидения спортивного типа.
502А Омыватель фар высокого давления.
508А Парктроник задний PDS.
520А Противотуманные фары.
522А Ксеноновые фары ближнего света.
534А Климатроник.
550A Борт компьютер.
606А Радио Business c CD.
676A HIFI Aktiv система.
789А Литые диски BMW R-16(резина 225-50).
832А Батарея увеличенной ёмкости.
945А Откидные спинки задних сидений.
